So I have had this weird issue every once in a while where I will take off and the engine will lose power. This under normal driving conditions leaving from a stop or even while in traffic. I have noticed that the timing will drop to about 5-6* and the power falls flat, it should be up in the mid 20-30's range but it just drops. I can't watch KR and timing at the same time, so I ended up just watching KR and as I took off the KR went up and up until I was at 13* under light throttle. I stab the throttle and the KR goes away and everything is normal for a time. Then it will happen again, may be several times in a row, or may just be once, may not happen for a week.
Car is 05 GTP no real mods.
Thanks,
Jeff
Thanks,
Jeff
