08 turn-signal & brake light issue
Dee Johnson
Appears the light in the front passenger side turn-signal shorted out. The bulb blew, put in a new one & no difference. Can't find a wiring diagram for this, but that bulb connection seems to direct not only the front turn-signal, but also the back on the same side & the brake light on that side. Dash indicator hyper flashes when it's tuned on; running light blinks on front, but not the signal itself, front or rear & just found out by being pulled over that the brake light on that side isn't working now either. Put new bulbs in all locations, front & rear - no change. The inside of the bulb connection for the burnt light in front looks burnt itself, but the metal connection in it is not corroded at all. Could this be the wiring harness that runs from the low-beam, high-beam & the turn signal to the main harness? Have also checked all fuses & all are okay.
Please advise, before I buy something I don't have to & still don't fix the danged thing!
Thanks!
Dee
