08' gxp
joedirt
wanted to introduce myself, name is joedirt. The wife has the car, just turned 109,000 and starting to have the tranny problems everyone talks about, woohoo got to love GM.............
good to meet you. Well it slips going into overdrive, seems like the TCC is not locking if you get on the gas while in OD (tranny jumps 1k rpm before "catching"). from what i've seen, it is weak tranny to start with.
The trans itself is pretty strong, will go for plenty of miles.
Just has some quirks to it. Can handle stock power levels with ease (if you arent beating the **** outta it everyday), just once alot is added, parts start to wear faster and tend to break from being too weak for whats needed.
A leading cause of failure on the GXP's is heat, the aluminum block of the LS4 always heats the trans up faster and cooks the fluid faster than the v6 cars. Coolers are a good thing to invest in.
The TCC might be your issue like you are saying, you can check out Triple Edge Performance and see if it has anything to add to possible causes.
Thank you for the good info. I have followed the servicing recomendations in the owners manual and changed the trans fluid every 50k with full synthetic. Do you have any recomendations on a good trans cooler?
I have left the car stock and she drives it 90% of the time. If i fix the tranny or replace it, i thought about upgrading a few things. We really like the car
