07 GP power steering leak
steelholder
Hello all, Ihave a PS leak along with some throbbing and whining sounds from my steering. The sound goes away when I top off the fluid but it leaks out the next day or so. I know I could take a look under but is there a usual source these leak from? My initial thought is to simply replace the unit but I may be off.
take the pass front wheel off, top it off and start the car, you'll see the leak. likely the return hose at the pump, if so you can cut the hose and re clamp it back on.
if its a metal line best to replace it. they can rub and wear a hole through.
