07 GP have to hold buttons on keyless entry.
ce9aevo
I'm new here. I just bought a 2007 GP. I have a question about my keyless entry and remote start. When using the key fob, it is slow to execute the command. On my truck and previous cars, I only need to press the button and it will open/close doors, etc. To unlock the GP I need to hold the "unlock" for 2 seconds.
"lock"- 3-4 seconds
"trunk"- 1 second
"remote start"- 4 seconds
What could be the problem or is this normal? Thanks for the help.
mine is about the same. the remote start is about 4 seconds. the trunk is about 3 seconds and the door lock and un lock is when i press it. but i might say your battery is going dead.
my lock and unlock is about 1 second
trunk is about 2 seconds
remote start (when it did work) was about 4 seconds
^^^ 2006 GP
Well, I guess it is academic at this point, but here is how my 08 works.
Remote start ~ 2-3 seconds (it is designed for a minimum 2 second delay)
Trunk ~ 1 second (I have to be pretty close for it to work, I believe this is also intentional)
Lock/unlock ~ near instantaneous
You may want to change the battery out, it might be getting weak.
Mine did that..then later stopped working. I took it apart and the thing that holds the battery in place was broken off. I just took it off I guess I could try to superglue it. How much did you have to pay for a new one?
totally reminded me, exact same thing went wrong on mine. that in addition to my reciever was bad.
