DnaProdigy
Hi All,
I'm having a bit of a problem with my 06 GXP. Randomly, upon startup, i got the Service Stability System / Reduce engine power message on the DIC. When the message is up the car drives like a dog. I replaced both front wheel bearings (both had a ton of play) but it did not fix the problem. I get 2 codes on the scanner (see below) but nothing too helpful. Anyone have suggestions? More info is below.
-Only happens on start up. Never while I'm driving.
-It is completely random.
-I get codes P0606 Internal Processor Fault. C0240 PCM Traction Control Not allowed.
-The airbag light flashes 4 times after startup.
-The check engine light is on sometimes, sometimes not. It is on sometimes when the power is reduced, sometimes not.
-The vehicle has 75K miles on it.
-The scanner shows the speed sensors appear to be working (and match each others speed). I did notice they say 2 mph when I'm standing still.
