04 turn signal?
shawns14
the front turn signal bulb in my 04 grand prix burnt out. how to i get to it to replace it? it seems like it would be hard to do it from the top or the bottom? do i take the lens off?
Thanks
the turn signal is in the fog light. its just two phillips head screws.
X2, just pull the foglight. Much easier to change when not installed. Not sure if anyone else had this problem but when mine when out it was actually a bad harness. Just fyi if changing the bulb doesn't solve ur problem. :)
the manual in my 2007 says to remove the headlight and go in from the top, if i rmember correctly. for other reasons I removed my turn signals with a philips head screw driver, two screws each, and I though, with the exception that they are low to the ground, would it not be easier to change the bulb this way than going in from the top?? anyway just remove them and change bulb and put back, that simple
not only did i have bad harness but figured out that autozone also doesnt even carry the correct 3 use bulb... just a 2... replacing a turn sugnal every 3 weeks got old real quick
