04 GTP with comp G package service alarm
428firebird
Hi guys; new guy question?
I've had my GTP since new, no mods to speak of, and about a week ago I saw, out of nowhere the service alams.
Traction control off
service stability control
service brake system
service ABS system
service traction control system
it came on once,I shut down the car did a restart and it went away. over the last week it comes on at start and stays on, repeating the alarms, I also have the idiot lights for these systems lit up. I live in Arizona, the car has about 70 K on the clock and being an in town car it has'nt needed a brake job. the only warranty work was on the transmission and HUD at around 30 thousand miles. I've read a few things about the ECU, as well as the wheel sensor harness connections. GM had a recall on some part of the braking but I'm not sure if it's applicable, Any help would be great.
THANKS!!!!
Sounds like you need to get the car scanned to see why the car is throwing those lights.
It could be as simple as a bad wheel bearing to a wire fault or at the worst the ABS modlue took a dump on you. Those can be sent off for repair to module masters for a price and like a 5 year warranty.
But I would first get the car scanned with a scanner that can read ABS codes and go from there.
could be a failing a speed sensor...too bad that means the hub assembly...pull abs codes
