04 GTP to 02 GTP transmission conversion
showtastiik
Need as much info on this subject as possible. I know the pumps, mode switches, manifold pressure switches & pressure control solenoids are different.
1. What else am I missing?
2. Are the Valve Bodies different?
3. Are the Valve Body Gaskets different?
4. Are the Channel Plates different?
Sent from my SM-N950U using Tapatalk
Obviously since the MPS's are different, the valve body's are different but more concerned about the VB to CP gaskets.
I'd double check the gear ratio between the 2. Also, is the 04 trans from a Comp G? I know the tapshift stuff is a completely different animal.
Yeah, both MN7 stock Supercharged 2.93 gear ratio.. No tap shift for the 04 Trans
