04 GTP Service ABS/ TRaction control
busagtp
I have an 04 GTP and i keep getting a message that i need to service my ABS and that my traction control and stability is turned off. I didn't do anything to the car but jack it up trying to fix what i thought was a starter problem is it possible that i could of clipped a wire or messed it up when lowering the car? All input greatly appreciated.
absolutely. an abs sensor wire to be exact. those 2 problems happening at the same time often suggest a bad wheel bearing/abs sensor, or a faulty connection between the sensor and computer
