04 GTP Mount Replacement Help
bdm1116
I replaced the engine of my 04 GTP about 20K ago and should have changed the mounts. Now, I've got some vibration/rattle problems that seem to be mount issues. Anyone have an idea of the difficulty/time required to replace the lower mounts and tranny mount? Is it a pretty straightforward process?
Its fairly easy, there was a writeup but for some reason it doesnt work anymore...
Remove the cover on that side and loosen the nuts on the mount. Remove the upper mounts. Use a 4x4 on the oil pan and support the engine. Remove the nuts and lift the engine enough to remove the mount. Put the wood block on the side you are working and make sure it spans to the edges of the pan. It will take about a half hour for each side.
