04 GTP differential?
ionroller
In my 04 GTP when I turn sharp sometimes, it seems like it isn't putting power down. The RPM's go up and it will sometimes shift, then when i straighten out it goes and has to downshift. I Just got it and it does have 100K, what should I do?
I doubt it's the tune. I still think it has to do with the axle. I had the EXACT problem with my SE. Swapped out the axle for a new one and problem solved
The boot wore out and mainly on tight turns under heavy load it wasn't getting any of the power to the wheel.
youre not supposed to be heavy in the throttle around corners. your car is trying to tell you to stop ****ing it up.
