Thank you in advance for your help. I have a 2004 Grand Prix GTP comp G. I am having an issue with an intermittent blower motor operation. Basically if I band under the glove where it is located, it starts up. I've already attached capacitor in the past and that did not make much of a difference. I did have the issue with leaking water in the passenger compartment and have long since had the GM shield put on that deflected the water from leaking in. My question is, what is the most likely cause of this, bad blower motor, relay...and if possible what GM part# do I need to replace.
Secondly. I am getting warm air blowing from the drivers side and ice cold air from the passenger side. Both blow at the same rate, but cold on the passenger side only. I've recharged A/C. Suggestions appreciated!
Thanks
Thanks
