04+ Gp with monsoon and onstar double din headunit swap
painthorsemoe
has anyone done this i see most people have went to the single dins but i want the double. id really like to have the nav and all that becasue i plan on traveling over the summer. if anyone has tell me what you used. and if you can post up some pics
sent from glade air wick spray
Are u wanting to swap to the double din navigation one that GM made or one u buy from best buy or something?
Sent from my DROID RAZR using Tapatalk 2
If u got one with navigation from best buy or somewhere it should come with everything for the navigation to work correctly. As for the factory chimes and sounds you will have to buy a wiring harness for that. If u got a GM navigation system it would cost more and you would have to buy a antenna and wire it in the roof or dash or where ever it goes
I don't have navi ATM but there's a add on available for it I might get down the road.
best pic i got, you will need at least 2 extra parts, u need to buy a dash kit like 20 bucks and an adapter to have ur door chimes and everything work i think the part is gmos-01 another 30 bucks. all easy to install.
He's put an after market shifter handle. U can see it in the pic
If you have the Monsoon sound system and you intend to keep the Monsoon amp then you will need the GMOS-04 adapter and it will run you anywhere from $80-$120 depending on where you purchase it.
when you swapped the radios you lost the calendar right? Are you still able to view your mileage? I have a 2004 grand pix gt and im looking to swap, i dont mind losing the calendar but i wanna make sure i can view the kilometres
Yea you'll lose the calendar feature...no buy deal 98% of aftermarket HU have a calendar anyways plus that's what a cellphones for. You will keep your kM/MPH.
