04-08 rear led turn signal. Need serious help
2dee11
Member
Hey guys has anyone put rear led turn signals in their 04-08 gp I have an 08 and am having serious problems with hyper flash and load resistors aren't helping
Any idea what wires they are? I've tried several combos and two different resistors
its just one bulb stock housing
If you're asking what wires they might be, I don't think you know what you're doing. Take some pics so we can get a better idea of the current situation
The front has black brownish grey and blue and I know the turn signal is blue there. The back has black grey and yellow so I would assume it's yellow.
Went to the store and got new resistors. Tested them with a multi meter and got 6.5 ohm hooked black to black and red to green/yellow. One thing to note is I am installing them on the male side of the connector to unplug the headlight. Shouldn't have a difference should it? This time I didn't even use those crappy splice things and still got same results. Do you have to have a resistor on each of the 4 turn signals? Or just where you put in a led bulb? Idk how I can wire up a whole audio system no problem and this is causing me so many issues
That looks like a nice invention. Although it looks like the green is to the ground and black is to the possitive on the resistor? Opposite of what I have... But after giving up and leaving it be I drove to the mall and my girlfriend pointed out it was working fine... So problem solved I guess? For now...
