chrsmi1
Awesome Level Member
This is a write up for all of us 04+ guys with fuel pumps that have access in the trunk. For the later 05-08 gp's with the pump in the tank, the pump should still be the same, but getting it out will be up to you. Can't help you there. I installed a walbro 255lph pump i got from intense. Works great with about 400 miles on it since last week. It's noticeably louder at start up, but not annoyingly loud. I won't go into how to do the Fuel pump rewire to the fuse box, but i would recommend doing that as well at the same time.
Step 1. Release fuel pressure from fuel lines. Best way is to start the car then pull the pumps fuse in the box under the hood. When the car dies, you're ready.
Step 2. Unplug negative battery terminal.
Step 3. Clear at least the forward portion of your trunk so you can reach the pump. Get in your backseat behind the driver side, put the other side access to the trunk down.
Step 4. Pull up carpet, and remove access cover to the fuel pump. Screw thingys are 10mm i believe. I just hit em with a pair of pliers since they're not really tight, at least on mine.
Step 5. Once you see your pump, remove the three fuel lines coming out of it. The outer two are quick releases. Push in the blue taps on both sides and they slide right off. The middle one you just have to squeeze and pull off. It might take some work to get the middle one off. It did for me. Some fuel will spill out. I had a couple of towels with me that i didn't mind throwing away for this reason. I put one on the laid down backseat and used to the other to try and clean it up when it spilled. The car smelled like gas for 3 days, but it's fine now.
This is what the pump looks like sitting in the canister in the car.
Disconnect the lines
Step 6. Disconnect the wires going to it. You can do this first before you disconnect the lines doesn't matter. Your choice. Put them to the side of the pump area. They'll slide down by the tank a bit, just make sure they don't go too far.
This piece holds the pump down in place. I used a screw driver to pry it left i believe. Get it off, and then the canister is ready to come out.
Step 7. Take Metal holding piece off. Once it's off, the canister can come out. You're going to have to twist the canister to get it out. Just be careful. I had a bucket standing by in the backseat on the laid down seat. I put it in there. Some fuel will still be in it and leak out, that's why i did it. You'll spill some, get over it.
Canister out.
Step 8. Once your canister is out, you need to set it some place where you can go to work on it. Get yourself a chair, it's easier to sit and do this crap. You'll probably need a philips screwdriver, pliers and some knife to cut away some wires. Probably some electrical connectors and tape too.
Step 9. Disconnect this wire that goes into the top of the canister. There are two connectors, a red and grey. Take them out then get the plug out the top. I had to pry mine out with a screwdriver. It was in there well. Get it out so you can separate the canister in two. The bottom part of the wire unplugs easy, but the plug itself will stay connected to the bottom of the canister as two of the wires from it go to the level sending unit or whatever it's called.
Step 10. Once the plugs are disconnected, separate the canister in two. There are two buttons that you push in to do this on the sides. Use your screwdriver, push them in, then pull the thing apart.
Canister separated
Step 11. With the canister separated you can go to work finally. Take the old fuel line off pump and off the top of the canister. If you're planning to reuse it be careful with it. Honestly, i'm not sure how this would go, cause mine was stuck on there like glue. I had to cut it off. Either way, cut if off and use a new line or get it off and reuse, either way get it off the pump and the top of the canister. Once it's off get the old fuel pump out of it's rubber sleeping bag and you're done with it.
Step 12. Once the old pump is off, it's time to focus on the new one. I got a new sock with my pump, so the old one was trash too. Here's the new pump vs the old. New left, old Right
Canister out.
Canister separated
