03 pontiac grand prix 3.1
94grandprix
long story short,heads got damaged and so I replaced them off another car,reassembled it all and wouldn't start so then rethinking realized both engines were on different strokes,now its basically out of time,can I fix it without taking off the timing chain cover?
Removing the heads does not take it out of time. You don't remove the timing chain to do this job.
It doesnt matter if each cylinder was in a different spot of both motors. You likely have a different issue.
What could it be,the car ran great before just blowed gaskets and then a rocker arm bolt stripped out so we just replaced heads and lower and upper intake,it's cranking as if there were no plug wires hooked up and my compression tester never showed any compression
Something is keeping the valves open then.
Are the intake and exhaust pushrods different lengths?? Did you make sure to put everything back in the same spot you took them from. I haven't taken a 3.1 apart like this, but those are just things that come to mind.
A guy just told me that 8 pushrods were longer than the other,I thought they were put back in were they came but could have got mixed up
Just hope you didn't knocked out the valves. That can occur when the push rods are not put correctly.
Sent from my SM-N920T using Tapatalk
Yup half are longer, usually you'll bend the pushrods so take it down again and start checking. I've seen a lot of people swap a couple of pushrods or the whole set it's usually one or the other.
I believe the exhaust rod are the long one and the intake are to short ones. I have an 01 GP se with a 3.1 and I recently did the heads on it.
Yes I can't remember the order but 01 grand prix intake are the short ones exhaust are the long ones and u can Google it to find the order
Sent from my SM-G928T using Tapatalk
