03 GTP yellow wire going through shifter cable grommet???
turbomazda6
I have an 03 GTP i have a yellow wire going through the firewall that comes from the ecu in airbox. it broke off when i was installing sub wiring today and i have no idea where it goes inside vehile please helppp
?? Need a pic, cuz all the wires coming from the pcm are wrapped pretty well and are really tough to "break" just running the power wire.
Well the wire pulled through the firewall and broken not by the pcm. it is a single wire with its own wire loom. My buddy has an 01 GtP and his does not have this wire.
Update wire is connected to pin 21 on ecu connector. I beleive this is the performance shift wire. where does this wire go inside the car?
