Randall Carlisle
Hey, been lurking thru the forum for better part of day. Nice forum. My wife has an 03 GP GT.
I am driving it this week and it has no heat. So from what I've read - i either need to flush heater core and bleed, or need actuator doors. This morning I had no heat. Temp gauge reading 180 or so, but would go up to 200ish at stoplights and then drop back down when moving again. I can hear the compressor kick in when I turn the fan on when it's on defroster setting. Both sides seem to be equally cold when turned to full hot. And even colder when on defroster. Will check heater hoses when I get in this evening. It does have coolant but was a tad low. Dexcool 50/50 added.
There are no fuses for blend doors, correct? And the blend door actuator is what is controlling the amount of hot/cold, correct? These are electrically operated, not vacuum, from what I have read. Fan works in every position, and it changes from defroster to vents to floor with no problem.
Only other issue I have with the car are those uncomfortably shaped headrests...
My first car was a 73 GP. $300 and was stout as an ox.
Randy
Randy
