02 gtp suggestions?
r3dr4ng3r95
Suggestions on what to do with my gtp. Looking for daily driver sleeper
Sent from my HTCD100LVWPP using Tapatalk
Headers, rockers, and whatever pulley you can safely run, and a tune. Depends how far you wanna go, but that should make a quick and reliable setup. Do all maintenance and fix any existing problems first, though
I've read it before or at least something similar. But unsure if updated. As far as who to get parts from
Welp you need to reread that thread several times. 104s are not needed at this stage 606s would be a better choice at your current stage. 160 tstat isn't doing you anything either but the stock tstat back in.
If youre going to change t-stats, get a tune for the fans and knock sensors at least. Also 606s will be better for your setup. You can get some speed daddy headers (slp knock offs) from ebay that are decent for the price. Start with flow mods first and dont touch the pulley until you at least open the exhaust up more. Also buy something to scan for knock with.
That's why I went with the 104s. I had a knock issue and the t stat went with 160 cuz temps would reach up to 200s
