GP40TH
Hey Guys,
My 02 GTP is experiencing an intermittent idle surge when warm (fluctuates between 300-1500 RPM at worst, sometimes stalls) which will usually last about 30 seconds. It happens when I'm coming to a stop in gear, and sometimes when I press the throttle for the first time after the car has been started if I leave it alone to warm up. If I rev it up, it revs just fine, and giving it a rev usually stops the surging once the engine returns to idle. The car acts like its hunting for the right idle speed, but drops too low, then compensates by revving up too high, then drops too low again (this is sometimes where it stalls), then revs up high, and so on. It's like an unstable control system, and its not shaking or running rough. In the meantime, I checked the short term fuel trim and it goes down to -15-20% during the surging behavior and it smells rich. I thought it could be the idle air control valve since the TPS was reading 0% while surging, so I replaced the IAC valve, but no luck there. What was really strange was that the MAF sensor was reading pretty steady values during the surging, and there aren't any check engine lights. Please help!
Current DIC's: none
Ongoing DIC's: P1844-Torque Reduction Signal Circuit Desired By TCM (predates the surging issue)
CEL: not illuminated
Reccent repairs:
Battery: 2yrs old
MAF Sensor: 6 months old
Vacuum lines: Checked 6 months ago. Some replaced.
Fuel Pressure Regulator: 6 months old
Fuel Filter: 6 months old
Injectors: Cleaned 6 months ago
O2 Sensor: 6 months old
TB: Cleaned 8 months ago
Air Filter (Cone): 6 months old, pretty clean still
Plugs and Wires: 6 months old
IAC: Just replaced
Engine Modifications:
Cold air intake
ZZP 1.0 PCM
ZZP U-bend delete (w/out downstream O2 sensor)
SLP Catback
Current DIC's: none
Reccent repairs:
Battery: 2yrs old
IAC: Just replaced
Cold air intake
ZZP 1.0 PCM
SLP Catback
