justinmc84
I've lurked here for a long time and have found a ton of useful info, so I thank you guys for that.
Here's my issue. About 3 or 4 days ago, my 02 GT (about 143k miles) started having problems accelerating. At first it seemed to only be in second gear from about 2500-3000 rpm. The car would seem like it was sputtering or hesitating and having difficulty getting going. During this time you could also hear something going on and off (whirring) in the times when the car was chugging down. In other words, when the issue arises, you'll hear normal engine noise and then a strange noise, then normal engine, then noise, etc...
Also, the shift points seemed to be higher and I was lacking power across the entire range (not a lot but enough to be noticeable.)
This happens mostly when the vehicle is under load; going uphill or accelerating heavily. I unhooked the battery, let it sit, and hooked it back up. That seems to have worsened the problem.
It doesn't trip any codes, but my TCS and ABS light have been on for awhile.
Is there any directions you can point me in that can remedy the situation? I'm unsure if it's engine, tranny, torque converter, catalytic converter, egr, other electronics, etc... Help me please!
