    TIPS:
02 GT 4dr Central Ohio
Status
Not open for further replies.
smallheadz
Ok so I am going to sell my 02 GT. I will post pics tommorow since the camera will not take a good pic in my dark garage. Here are all the details of the vehicle.
Things I have done in the last 2 weeks.
LIM gaskets updated alum , complete upper and pcv valve, injector orings, valve cover gaskets, water pump, radiator, tstat,elbows, key(not cut yet PK3M), keyless remote, front wheel bearings(not installed yet waiting to arrive), front pass regulator and switches, recharged AC, plugs,Battery
The car is a little beat up no rust. Everything works.
This car came from a towing company so it has odo discrepency since the mileage could not be verified but I found the original title in the car too so I know mileage is actual but title will still say discrepency. Odo shows 173k. Tires and brakes are decent. I have driven this car for about 200 miles and it does drive well. Only problem I can find may or may not be a big deal. First thing in the morning when I start off to work it takes a second for the car to shift from first to second. Very odd and only does it once. Doesn't slip it will lay rubber down. I have run this car up to 110 and performed ok.
$1750 will drive it home Will be for sale and setting in the driveway by the weekend. This car sat almost 2 years at the towing company so I just brought it back to life.
Forgot to add that I installed the updated fix for the leak on the pass side thru heater box. Part was only $4 but its done so no more wet carpet
Status
