I have a leak and it's around where the throttle body is. It runs around the uim gasket on that side but I can't seem to figure of its tb gasket or uim gasket. Last time I saw the leak, I found a loose stud on the tb to uim on the bottom so I tightened it but stripped the stud so I just switched the studs around and put the bad one on top.
So I plan on going to jy and pulling some tb to uim studs and replacing the tb gasket.
I just replaced the uim and lim gaskets a year ago and I did the uim with all new plenum, and dorman upgraded egr pipe for uim. What could it possible be? Coolant is only coming from the tb side. I have no coolant in the oil.
Like I said the coolant leak is right around under the tb and I can't tell if it's uim, the uim gasket, or tb gasket. I dread pulling uim in this cold michigan weather
