02 -04 trans swap
Nick McNamara
I pulled a trans from an 02 gt and put it in my 04 gt. I cant get it to crank. is there a park sensor switch some where that i cant find or has anyone had same problem?
In order to use an 04 trans on an 02, you would need to use a 2003 GT ECU (the trans electronics, and ECU drivers are different 98-02 and 03+), and swap the external range switch from the 02 trans onto the 04.
That should get you up and running.
-Rob
