01STOCKGTP
I have an 01 stock GTP. It has recently started shaking while under moderate acceleration especially when I have several people in the car. Any ideas on what might be causing the problem? THANKS!
Cv axle. Just replace both.
Sent from my Droid
Tie rod end most likely isn't contributing to the oscillation, but still worth replacing then doing alignment. When the CV joint wears out it can have play in the joint, so when you apply torsional load to the joint/shaft it creates an unbalance and thus your wobble. But when the load is reduced on the axle, it returns to center and is balanced. That is why it only shakes on accel. I had the same issue when I purchased my GTP. I recommend both, just because I like to do thi gs in pairs. Chances are if one is going bad, the other is on it's way.
Sent from my Droid
I would recommend acdelco. Reman shafts are kinda luck of the draw. Not sure on price. If you can do your own brakes, you could probably tackle this with a write up. You could try the search, i don't know of any write ups off hand.
Sent from my Droid
You can visually check them by looking at the boots on the inner and outer joints. If they are wet or slinging grease everywhere then that's the one to change. The only way I found I had a bad pass. side inner joint was by accident. I leaned on the shaft while doing something else under there and heard a clunk. Pressing down on the shaft showed I had play in the inner joint that was causing a horrible vibration on accel and any speed above 50.
