01 gtp random miss
redflash
Hi everyone! it is awesome to be here, what i have is a 01 gtp that i just traded my 94 civic for. but it has a miss. i ran the codes on it and came up with two. po141 02 sensor and a po300 random miss fire. where is the best place to start. thanks for your help!
Do a tune up. Plugs, wires, fuel filter and change the oil unless you have record of it being done within it's proper maintenence period from the old owner. (The oil change won't help the miss but it's just a good idea)
ok thanks! I have already changed the plugs ( champion) should have bought delco. and new wires. it is still missing. no change. when the engine is at running temp, it will surge at idle. it will go down to nearly a stall and then back up to a slight high idle. but no code for that. i have checked the coil pack and all coils are fireing. all wires are on the right plugs also.what all can cause a random miss fire.
idle sensor. and i unplugged the maf sensor and the car runs as normal. i no that should change but it doesn't.
