'01 GTP - Electrical Gremlins [lights] troubleshooting?
ELECTRICxWIZARDx
Picked up an '01 GTP Sedan 150k mi, a few days ago, and having some trouble with electrical systems. Looks as though a previous owner did some shoddy electrical work, mainly audio, and trying to troubleshoot, looking for advice. Never messed with a vehicle that has a BCM. RAP, HUD, and DIC do work. Aftermarket radio was replaced with my own aftermarket head, using same 21-pin harness that I used on my old car, '00 Malibu.
1) fog lights won't come on - read they only activate with parking lights or lowbeam headlights engaged, and will kick off with the high beams engaged. Nothing. Switch, relay, or other likely culprit?
2) no interior domelights - Car has sunroof, and the two press-switch style reading lights in small upper console. Haven't checked bulbs yet.
3) no taglight - changed bulb, no dice. connections on socket themselves are clean.
4) DIC flickers - the left side of the DIC will flicker, and also echoes turn signals when they are on.
5) Blower Motor remains on with key off - figure a relay went out, and someone wired it direct. troubleshooting tips?
6) weak door chime - sounds muted/distorted. replaced rear speakers, front right works, front driver side does not.
That said, I friggin love this car. Never want to drive something without a HUD again!
My first steps would be to disconnect anything to do with the radio. Then go after the blower motor problem and put it back to the way God <and GM> intended.
The idea is to undo anything that was done to the stock system, then trouble shoot the original problem. Hopefully you find 1 major problem that is causing many symptoms.
I find the turn signals flickering the DIC interesting.
WEAK OLD BATTERY?
CORRODED GROUND POINT. These cars have.... grounding issues, to put it mildly. Start simple, the battery. Dirty/loose cables, grounds to the frame, to the engine. There are "Harness" ground points for lack of a better term. Under the hood, under the dash, under the carpet. Check for water damage. <flood car?> Wet carpet? The sunroof drains have a tendency to fall off inside the roof and dump water into the pass compartment. Is it all dry in there? Also the AC drain clogs and fills the blower with water then drips out into the passenger front footwell.
There are a ton of resources on here including all the grounding locations in a PDF somewhere...
Awesome, thanks for the tips.
Question, would I need to track down a stock radio? I've read something to the effect that removing it can screw all kinds of stuff up, and some installs just relocated it to the trunk to make onstar, etc, play nice.
I don't think it's a bose system, RPO codes on trunk sticker show -
UP3: AM/FM STEREO, SEEK/SCAN, COMPACT DISC
UW6: SPEAKER SYST, 6, DUAL F/D TWEET & WOOF, DUAL EXT
Forgot to mention, keyless entry fob does not work either. Have not ruled out damage to fob itself though.
I've seen [well, smelled] no obvious signs of water damage. Carpet is not discolored.
But, tomorrow I'll go by a parts store, have them test the batt & alternator, then progress from there.
Checking Grounds is the easy step 1. If all Grounds are good, things get.... fun...
First thing I would do is pull the halfassed work done to the wiring. Get the harness behind the dash as clean as possible. You don't have to get an OEM stereo, just undo all the crap for now. Cap the ends of all the wires you expose to prevent any crossing, aarcing etc.
Check for some of your issues. If they are gone, great, if not then further teardown is needed. Are the HUD and DIC factory options on your car? If yes, great, if no then you need to dig deeper and find any modifications to the wiring. This could involve literally pulling the entire dash out.
Also, not for nothing, check out the BCM. If something has happened to it, it could cause many of these issues.
Sent from my ASUS_Z00TD using Tapatalk
The biggest bummer on these, is that in order to even swap in a code matching Junkyard radio, they need to be "Programmed in" by the Dealer, or someone with a Tech 2. Anti-theft, VIN matching etc.
Yes, pain in the ass. Door chimes, Sat radio, a feed for HUD info all goes thru the stock... bastard of a radio. There are new "rebuilt" radios on ebay, they even come with an Aux in jack on the face-plate <Phone Jams!>. I don't remember if they need programmed in or not. Round 300 bucks though.
thanks all for the advice.
So, got the tag light working. Ended up being a bad connector, spliced in a new one, good to go. Connections soldered and wrapped in heat shrink. One gremlin down.
Did some poking around, found that the dome lights were non-functional due to the fuse being pulled. Replaced it and.... They won't turn off. Explains the pulled fuse, haha.
There is also an extra wire jumped into the interior fuse box, under the DRL fuse. Not sure where it leads, appears to go through door jamb to underhood area, then disappears into the factory split-loom, near the battery.
I'll poke around more this weekend when i have the time.
Do you know if the non-bose audio used a separate amplifier as well? From the bit I've looked around, there are some [4, looks like 2 conductor] extra wires leading from above the AC control panel to behind the glove box, i suspect it is wiring to bypass a stock amp.
As far as I can tell, HUD and trip computer were standard on '01 GTPs. Found a pdf spec sheet from GM. What I'm calling the DIC is the little screen that indicates doors open, boost gauge, and will cycle through Fuel Used, Range, Oil Life, and MPGs. Is DIC or trip computer the correct term for this?
How would I go about checking the BCM, or is that best left to a shop? Also, I'm assuming that's the box near the onstar unit in the trunk?
Still scratching my head about the blower motor running with key off though. Gut instinct tells me a relay was bypassed, and a constant hot was used rather than keyed.
Chimes didn't use the radio until later I'm fairly certain. This car being an 01 had them handled separately. 05 I think is when chimes were integrated.
OP: I should clarify, are they the units from the car. If they are scrapyard pulls or used units something could be wrong with the install.
The wire in the DRL circuit sounds like someone wanted 12 Volt when the key was "on." This is often the case with dash cameras or other after market AV accessories.
Interior lights being "always on" screams a short in the system.
I am sorry to be rude, but severe electrical gremlins are on the edge of being outside DIY territory. If you have experience or a friend with experience you can really proceed, but if you are coming in totally blank a shop is recommended. Shorts can go as far as causing fire in the vehicle. Additionally, GM is obnoxious when it comes to swapping many components that are integrated into the system, offend requiring them to be programmed to VIN match the rest of the system or they will not function correctly.
@nox - what units are you asking about? I'm confused.
No offense taken, I'm starting to lean towards letting my usual mechanic take a look at it. I'm far handier with a wrench than a multimeter, but do have a grasp on basic electronic repair, due to learning to solder to fix (or mod wiring scheme) guitars/basses. Diagnosis is where my skills lack. Gut tells me it's gonna end up being the BCM though.
Main troubles as of right now is the lack of interior lighting, fog lights, and blower motor running with key off. All of which, just minor inconveniences. I bought this as a second car anyway, to have something more fun, comfortable, and better mpg's than the truck. ['92 1/2 ton Chevy SWB.] Knew it would need some sorting out going into the purchase.
Everything appears stock, except audio system. There were left-over wires [remote on, ground, rca] to the trunk for subs, which i have now removed.
Oh! I followed the extra "mystery" wire from the DRL fuse the other day. Interior fusebox--> Door Jamb-->Under Hood --> is spliced into the wiring for the passenger side turn signal bulb. It's soldered into [i think the brown wire, iirc.] When I unplugged from fusebox and turned key back on, something in the dash started making a constant solenoid click, like a bad starter but not as loud. Couldn't pinpoint source, but definitely driver's side. Thinking back, possibly ignition related? Did not function check outside lights w/o wire.
At this point, i threw in the towel. Plugged the mystery wire back in, and decided to just leave it the heck alone for now. Switched focus to restoring the headlight lenses and a full int/ext detail.
Edit to add: forgot to mention, TCS OFF button and low trac DIC lights do not function either. Hazard flasher switch and shift-lockout-something are missing as well. Keyless entry does not work either, but have not ruled out fob as problem.
Are the HUD and DIC the units from the factory or are they swapped in replacements? Even if the car had OEM HUD and DIC if they got replaced and installed incorrectly it could cause issues.
