Ok so here is what is going on with this car plus a little background. 2001 GT
Car has 89k had 71k when we bought it about 2 years ago.
Up to last november I had replaced fuel filter, PS pump, alternator, and front brakes. Nothing too major. Then on our way home from Thanksgiving the transmission goes out. This is too early for problems with this tranny. I work at a tranny shop so we put an overhauled transmission in.
The car ran fine up until about 2 weeks ago when my wife(her car) began complaining about a shudder during acceleration. I took the car to work and hooked up the scanner.
No codes. I drove and watched the miss fire counter. The scanner recorded random miss fires in several cyls. So I replace plugs and wires, then drove. The shudder was still present.
Next I swapped coil packs and ignition modules with a known working set. The shudder continued.
Next I drove again using scan tool and recorded only one miss fire out of 3miles of driving. Shudder was still present.
Next, assuming the problem is still a miss fire and that the scanner is not picking it up, I checked the injectors as well as tested that a signal was being sent to the injectors from the computer. All was good.
Next I un hooked the EGR and drove, still a shudder.
Next I un hooked the MAF and drove, still a shudder.
I hooked up scan tool again and drove, the only codes were from when I drove the car with the EGR and MAF unplugged. Shudder is still present with no recorded miss fires.
I concluded that the miss fires were a seperate and unrelated issue to the shudder.
Today I drove and watched the TCC slip, thinking that it may be a transmission problem. And the converter showed excessive slip. However, I can not determine the cause.
If the TCC was bad it should set a code and shudder consistantly during when coming in and out of lock up.
It could either be a bad converter or low voltage being sent to the TCC causing it to slip in and out. It is possible that this is happening so fast that the computer fixes the problem before it can set a code.
So anybody want to buy a car?
