Hi from ttrech,
I had 1 of those 3.8 oil/engine fires. I repaired it by buying a used engine @ the bone yard and replaced the engine wiring harness and other parts destroyed in the fire. Now I am getting the SES light and will not pass the MA. state emissions test, throwing OBD II codes PO102 MAF sensor flow circuit low input,I have tried 2 different used sensor with the same results so I thought the ECU could b bad so I got a used 1 and installed it with the same results. does anyone have any ideas about what else I should do to track down this problem and get it resolved.
Any help would b appreciated.
Thanxs ttrech
Thanxs ttrech
