Most important when cleaning the throttle body is to make sure you inspect and if necessary clean the passage way for the IAC (idle air control) valve. This passage way, along with the pintle seat builds up with carbon and causes funky idle, remove the IAV from the throttle body very carefully not to bugger up the pintle valve, the pintle valve itself must also be cleaned too, an old toothbrush and carb. cleaner/brake cleaner works great to get into both sides of the passage ways. Carefully clean the end of the pintle valve taking care not to push, pull, turn, or change it's position, replace or inspect the o-ring on the IAC, a little oil on the o-ring helps prevent pinching on re-installation.
