01 GP Drivers Window issue. Need Help.
mtk469
Hello all. Been reading hear for quite some time but my first post. I have a 01 4dr GP GT and this morning while driving to work I went to put the drivers window down a smidge and then it wouldn't go back up. You can actually push it down or pull it up with by hand. When you push the window control button do can hear it engage and like it is trying to move the window but nothing happens. I took the door panel off to push the window up and to see if it is was on the track etc but its raining and I didn't have much time to spend. Any thoughts on where I should start with trying to fix the issue. Don't have a ton of funds to replace everything until I get it right.
THanks for any hlp you all can offer.
Matt
I just replaced my driver's side, rear regulator and motor. Same exact symptoms. After I pulled out the old regulator and motor, I found out that the one cable that is attached to the sliding part of the regulator had pulled out of the plastic holder. The plastic holder was broken. Can't fix this. So, I bought a used regulator and motor from Ed Morad for $22. Easy to fix. 4 bolts for the regulator, 3 for the motor and 2 for the window. Altogether about 1 hour total. Lubed the regulator with white lithium grease and the felt window tracks with dry silicone spray.
Everything works great now.
