'01 alignment ?'s
riceburner
well first, i did an alignment diagnostic and the picture is my results, but my ?'s were, can you adjust the caster on these? and second, since the tie rods are on piece w/o a lock nut, how do i adjust the toe?
The tie rods aren't one piece, there's an inner and an outer. You adjust them by loosening the jam nut and turning the inner rod, effectively screwing the outer tie rod end further on or off. I believe you adjust the rear with one of the lateral arms.
I don't think there's a castor adjustment, but I could be wrong on that one.
