So here's the deal. I've been having this problem for a month. It started when my car shut off while driving. I was able to restart the car after I pulled the ECM(sense) fuse with the car in the on posistion and putting it back in. It got to a point where it would only drive 1.9 miles or a half mile at a time. After replacing the CPS it will start and shut off 30 secs later. You can't restart the car unless you disconnect the battery and wait 10 minutes to reconnect it.
So far I've checked the Ignition Control Module for cracks and other faults, replaced my fuel pump (with a Walbro 255), cleaned my MAF, bought another ECM and replaced the Crank Position Sensor. I've also tried starting the car with the MAF unplugged. None of this has worked. After I replaced the CPS the Service Engine Soon light shut off.
I'm tapped out of ideas.
