Identify obscure part, and how to replace
imavery
Accidentally broke the lower plastic piece that secures the the Coolant Reservoir from bumping into the pully system. I've found a few at the local pick and pull, but I can't figure out a good effective way to remove them without breaking something along the way. Considering just ordering a new one, but not sure what the actual part is called or the part number. Any thoughts on what the part number is, or how to remove one already installed? I'm new to this.
Thanks in advance
Usually has a small slot in it, you can use a flat head to pop the middle part up, then pull with finger or needle nose pliers to just pull on the middle part.
