Thread: Noob tuner - ltft question
Results 1 to 5 of 5
  1. #1 Noob tuner - ltft question
    SE Level Member L67PWR's Avatar
    May 2013
    New Jersey
    I have read the "starting HPTuners" sticky thoroughly, After I get my Fuel trims dialed in, I start airflow tuning. When I adjust the mass air table my ltft's go back to terrible numbers. Am I doing something wrong? Btw, after getting to mid 11's(AFR) at wot my ltft's are pegged at -16.
    00 GTP - Bored block, Eagle Crank, XP Cam, PC Headers, P&P Heads/Blower/TB, 3.0 Pulley, Meth kit + many many more...
  2. #2 Re: Noob tuner - ltft question
    Jan 2009
    Tallahassee, FL
    You tune your part throttle airflow first, then WOT tuning. Only during WOT are you also tuning the afr directly. The computer is going to get the car to 14.7 during part throttle no matter what you do.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Noob tuner - ltft question
    May 2013
    New Jersey
    Hmm. According to the instructions you adjust the whole Maf table to get ltft between -5 and +5. Then you adjust the 7000htz and higher for wot runs. Once that's done you scale the lower end of the table do there aren't many spikes. It seems like I was wasting time trying to get good trims only to change the whole table again. I hope I'm explaining this right. Do you understand what I mean?
  4. #4 Re: Noob tuner - ltft question
    Jan 1970
    Maquoketa, Iowa
    PE enabled the whole time? How long do you let the trims relearn before messing with them again?
  5. #5 Re: Noob tuner - ltft question
    May 2013
    New Jersey
    No PE during trim tune. About a half an hour of driving in between each adj.
  1. Noob Question smh
    By ajoliver2010 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2013, 03:47 PM
  2. Hp tuner noob question?
    By Quarterpastgone in forum PCM Tuning
    Last Post: 11-12-2012, 10:24 AM
  3. LTFT Question.
    By WolvesSoulZ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 02:21 PM
  4. noob question
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 10-15-2010, 11:41 PM
  5. noob question....
    By OhsoKleaN in forum Tires & Wheels
    Last Post: 02-08-2010, 02:32 PM
