Thread: HPTuners: Programming for Dummies
Results 1 to 20 of 22
  1. #1 HPTuners: Programming for Dummies
    Omaha, NE
    There aren't a lot of HPT specific writeups out there, especially for a new tuner to use. I found this helpful as a quick reference when I removed torque management and fan temp adjustments, so hopefully someone else on here can find some of the information useful as well.
    NONE of this info is mine, it is thanks to baddogZ28 at LS1LT1.com
    HPTuners programming for dummies - LS1 Forum : LT1 Camaro, Firebird, Trans Am, Engine Tech Forums
    Here is some info help you guys get started tuning with HPTuners. Credit to ozorowski, Keith from HPT, and WS6snake-eater from HPtuners bulletin board for compiling this basic info.
    DISABLE ALL TORQUE MANAGEMENT
    Your a hardcore racer now why do you need a computer to tell you how much power you can have.
    1: Open your editor, go to Edit>Transmission>Torque Management.
    2: Set Abuse Mode Enable False
    3: Set Abuse Mode RPM, Abuse Mode TPS and Abuse Mode Speed to 0
    4: click over on Abuse Mode Torque Reduction vs RPM. I am referring to An A4 camaro SS here so dunno about anyone else. Set all values in Normal to 0.
    5: You should now have NO TORQUE MANAGEMENT.
    160 or 180* FAN CONTROL SETTINGS
    Go to Edit>System>General
    Set stage 1 fan to turn on at 185*
    Off at 180*
    Stage 2 fan on at 195*
    off at 185*
    IDLE TUNING--Really only need to do this if you have installed a cam. Special thanks goes out to WS7 on Ls1tuning.com
    Idle Limiters -->
    Go to Edit --> Engine --> IDLE --> IDLE RPM --> Target Idle speed VS ECT
    Idle Speed: 950--Start at 950 to get car to idle, then lower 25 rpm at a time until you get idle you like that will keep car running. General rule of thumb, keep anything with AC 50rpm higher than your AC OFF.
    Go to Edit --> Engine --> IDLE -->IDLE AIRFLOW --> IAC Park Position Airflow vs. IAT: Raise all points from -40C and up to 21
    Go to Edit --> Engine --> IDLE --> IDLE AIRFLOW -->Idle Airflow vs. ECT: Idle Air In Gear: All points 68C and up to 8.6 (Mine are at 9.6). This menu RIGHT HERE is the key to idle.
    Go to Edit --> Engine --> Airflow--> General --> Primary VE vs. RPM vs. MAP --> Multiply column 400 rpm by .60. Multiply column 800 by .80. Multiply column 1200 by .90.
    Go to Edit --> Engine --> Spark Advance --> Low Octane: Add 2 deg to all points 400 to 1000 RPM, .08 to .32 g/sec. Copy this table to High Octane Table.
    Take the car for a drive and check your idle. If the car goes on cruise control reduce the Idle Air in Gear Table .2 (further if necessary). If the idle holds at 2000 RPM for extended periods of time reduce the P/N Airflow Decay table for all points above 10 MPH by 5% (multiply by 95) until this stops. Be vary careful on this table.
    If problems idleing, after you do all these idles steps, Go back to Idle Airflow Vs ECT, add 1 point to WHOLE ROW, whether idle in gear, or idle in p/n, and add 1 point at a time to WHOLE ROW, re-upload tune to car, and repeat until car idles. I don't know how much is too much, but I just kept adding 1 to the row, and car idles NICELY now. Now fine tune your VE
    LTFT (VE) TUNING
    First off, unplug your Maf sensor. As of right now, I don't plan on plugging it back in. Don't see any reason to.
    Special thanks goes out to WS6snake-eater for most of this part...
    1: Unplug MAF (Replace with strait bellows if you do not have intentions of ever using a MAF again ie. always speed density.)
    2: Disable the SES lights for MAF codes P0101, P0102, P0103 (No check engine light.) Do not completely disable the codes or the PCM will not fall into SD mode. Only turn off the SES light, DO NOT DISABLE THE CODES THEMSELVES!
    3: Start up your scanner. Start up your histogram. Now, click File then connect. Go to tools then VCM Controls. Click on Fuel & Spark. Reset Fuel Trims.
    4: Drive around at a MINIMUM of 15 minutes. Try not to floor it but if you do it seems to be ok.
    Stop logging, save data, do not turn off engine until you save your data or you will lose your log. Now, look at your ltft's. Open up your editor and go to Edit>Engine>Airflow and look under MAIN VE click on Primary VE vs RPM vs MAP. Click on that.
    5: Let's say at .800, .28 which is equivalent to 800 RPM's you have 4 which is equal to +4. For ALL YOUR TRIMS you want between 0 and -4, so what I do is do whatever it takes to get to zero. Easy rule of thumb here if you want number smaller, add you want number bigger subtract. So, we want to bring that DOWN to 0 so ADD 4 to .800, .28. Let's say 2.0, .20 is -10, SUBTRACT 10 from 2.0, .20 to bring it UP to 0. This will not work out exactly but will get your PRETTY CLOSE. Do this for all values until everything is between 0 and -4.
    6: Repeat steps 3-5 until ALL values are between 0 and -4. Try and do this all in same day for best results.
    7: Once all values are between 0 and -4, look at your 3d graph. Pretty choppy huh? Click on polynomial smoothing ONE TIME. This will take a lot of choppiness out. Now rescan, and do step 5.
    8: Copy High Octane table to the Low Octane Table (computer reverts to low octane table when MAF is unplugged, this assure optimal timing)
    PE TUNING-ONLY after your ltft's are all BELOW 0.
    This should be easy so read on...
    1: Open up your scanner, do not worry about resetting your fuel trims. In fact, you want your fuel trims to be learned at this point. You hopefully have driven 100+ miles since configuring your ltft's.
    2: Open histogram, and do a nice 0-70 or preferable 0-100mph run. Look at your Knock Retard FIRST. If you have Knock retard skip to next section then come back here. If no Knock, continue.
    3: Again if NO KNOCK, look at your air/fuel tab at 100 mark. I do not know what measurement the 100 is, but that is what I use for my reference. It is best to dyno at least once to see what mv your 02 sensors like. Mine seem to like 890mv. Anyways, look at where your mv's are vs. what your car likes.
    4: Let's say at 100, 3200rpm, your are at 950mv. We want to bring that down to 890mv. I do not yet know exact equation, but go to your editor then Engine>Fuel>Power Enrich Look at PE Enrichment category and click on V8 Mult vs. RPM. Make sure plus is bubbled in and selected is bubbled in. Now, in this case we want to bring it down, so SUBTRACT .01 NOTICE THE DECIMAL VERY IMPORTANT. If you are Lean -BELOW 890mv then ADD .01 at a time. I know this is a small increment but you do not want to blow up your motor.
    5: After making your changes, go back to step 2 until you are in range you want to be in.
    6: Pat yourself on back you have a halfway decent tune now.
    ELIMINATING KNOCK RETARD:
    1: Look at your most recent Histogram log from your scanner. Look for ANY KR. So let's say at 4000x .20 rpm we have 4 degrees. We want this to be 0, so we have to SUBTRACT 4 from this cell. As far as I know you can't have anything less than zero here.
    2: Go to edit>Engine>Spark Advance. Click on Main Spark vs. Airflow vs. RPM Open Throttle, High Octane. Now go to .20 4000 rpm AND/OR whatever other tables have KR and SUBTRACT whatever degree of Knock Retard you have. You can subtract by simply clicking on plus selection and in that little box type -4 or whatever number you have to subtract by and click commit.
    3: Run a new scan and you should now have NO knock Retard. If you do, repeat from step 1.
    A4 TRANSMISSION SETTINGS:
    1: Well, you should have already disabled torque management.
    2: Start at Edit>Engine>A4 Shift Speed. Look under WOT Shift Enable %TPS: Set it at whatever you like. I set down to 90% because when I floor it I want power quick. Your talkin ga few milliseconds to go from 90 to stock 95% right, LOL.
    3: Disable %TPS Set this to about 10 lower from your Enable.
    4: Look at WOT Shift RPM vs. Shift. For my STOCK camaro I set to 6000 rpm, cuz if you look at my dyno, it is dropping after 6000rpm so I figured just have it change at 6k. After 6krpm it will take a few hundred more anyways to shift.
    5: WOT Shift Speed vs. Shift--In an A4 here is a formula I pulled off ls1tech.com make sure to thank 99ssleeper over there. He posted this:
    MPH =
    (RPM x Loaded Radius of the real wheel) divided by
    (Tranny Gear Ratio x Final Gear Ratio x 168.06
    If you have stock wheels and tires, the Loaded Radius is approximately 13.125"...otherwise just measure from the ground to the center of the wheel.
    A4 Trans Ratios are
    1st..3.06
    2nd..1.62
    3rd..1.0
    4th.. .8
    Fianl Gear ratios are 2.73s or the optional 3.23s (RPO GU5 I think...??).
    6: Shift Speed vs. %TPS vs. Shift. LEAVE AT STOCK
    7: MOVE TO SHIFT PROPERTIES TAB
    8: Look at Desired Shift Time. Click on Normal FORGET about performance if you are driving a camaro. There is no performance in a camaro, LOL. I basically guessed here, and could use some input here. For the first half of
    the torque band, I set shift time to .500 so you get nice soft, smooth shifts. Starting about midway, I decreased to .250 and for last 1/4 I changed to .100. I heard you do not want to go below .100 or else you will run into some kind of gear crossing? Please feel free to fill in here.
    9: Shift Pressure-Ok this is kind of weird and don't understand it, but what I PERSONALLY did was again take half of chart and to the left. Take this and set to a LOW # like 10. I have a shift kit in my car, and setting first half gives me nice smooth shifts. You would never know I had a shift kit or torque converter in my car. I then took middle and started beefing up shifts in increments of 10 then increments of 15. By far right of table I have shift pressure up to 90. Now, when you drive my car at 0-1/4 throttle it is SMOOTH. 1/2 throttle, you can feel a nice crisp shift. WOT it chirps tires from 1-2 and 2-3 shifts. NICE and hard.
    10: Upshift/Downshift pressure I don't understand. If you do, teach me and I'll update.
    11: If you have a shift kit, leave max line pressure at 90. If not you can prob. up to 100.
    12: Below, courteousy of Blue_Falcon
    If you don't want your torque converter to lockup in x gear, just go under TCC apply in x gear and change all of the values to 256.
    13: Transmission tuning DONE.
    TURNING OFF REAR O2 SENSORS:
    Thank you Keith, HP TUNERS
    You'll want to go through the DTC list and find all sensors of both bank 1 and bank 1 that are labeled as Sensor 2.. Sensor 2 indicated the rear sensor (on V8 applications).
    You will want to leave the DTC On/Off flag as it is, but will want to set the error mode to "No Error Reported".
    CHANGE TUNE FROM AUTO TO MANUAL OR VICE VERSA:
    1) Get tune from Bin file repository or somewhere. Copy out of someone with same year car as you if you like.
    2) Upload file just as though you would any other file.
    3) Enjoy you now have a M6/A4 program.
  2. #2 Re: HPTuners: Programming for Dummies
    SE Level Member Enzo354's Avatar
    USA
    Hopefully this info helps on your top swap!
  3. #3 Re: HPTuners: Programming for Dummies
  4. #4 Re: HPTuners: Programming for Dummies
    Rofl at disabling torque management.
  5. #5 Re: HPTuners: Programming for Dummies
    GT Level Member 99GPGTP's Avatar
    Rome GA
    this may be a dumb question. im about to buy a hp tuners program and i want to know if i can program other cars besides a gm.
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  6. #6 Re: HPTuners: Programming for Dummies
    So no update on the bad advice?
    Also, they sell one for GM, one for Ford and soon one for Mopar.
  7. #7 Re: HPTuners: Programming for Dummies
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by 99GPGTP View Post
    Yes, go to there site it explains the credit system and what cars are supported. Ive done a G8 and a few ls1's on mine
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: HPTuners: Programming for Dummies
    But those are both GM products?
  9. #9 Re: HPTuners: Programming for Dummies
    Hagerstown,Md
    HPTuners.com >> Performance At Your Fingertips
    They support some ford, but yeah mostly GM
  10. #10 Re: HPTuners: Programming for Dummies
    Kemmerer, Wyoming
    is there a way to reformat a dhp scan into a hpl scan?
  11. #11 Re: HPTuners: Programming for Dummies
    May 2008
    Schuyler, NE
    Not to my knowledge. Doesn't DHP save it's scans in .xls format?
  12. #12 Re: HPTuners: Programming for Dummies
    Kemmerer, Wyoming
    no, its a .csv
  13. #13 Re: HPTuners: Programming for Dummies
    May 2008
    Schuyler, NE
    OK. Looks like it can't be converted anyways. Why would you want to do that anyways?
  14. #14 Re: HPTuners: Programming for Dummies
    Kemmerer, Wyoming
    use it for tuning
  15. #15 Re: HPTuners: Programming for Dummies
    May 2008
    Schuyler, NE
    Just scan with HPT instead.
  16. #16 Re: HPTuners: Programming for Dummies
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SgtMarshal View Post
    you can export a hptuner scan as .xls and open an .xls scan with hptuners. you can open a .csv (dhp scan) with excel. you could save that scan as a .xls and open it in hptuners theoretically...however, i have never tried it and dont know if it works in the real world...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  17. #17 Re: HPTuners: Programming for Dummies
    Kemmerer, Wyoming
    does turning off the O2 sensors actually disable the cat diagnostic?
  18. #18 Re: HPTuners: Programming for Dummies
    On 2001+, no it does not.
  19. #19 Re: HPTuners: Programming for Dummies
    Kemmerer, Wyoming
    when doing VE tuning and disabling the maf, wouldn't it be easier to enter 0 in engine diagnostics/airflow/maf sensor/maf freq fail high? that way you don't have to unplug the maf and tune out the codes.
  20. #20 Re: HPTuners: Programming for Dummies
    GTP Level Member
    Jun 2016
    Cleveland ohio
    LTFT (VE) TUNING
    Shouldn't number 8 be first. If you unplug the MAF it goes to the low octane table. Wouldn't you you want to get the trim readings using the high octane table while you are getting the scan?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  1. looking at hptuners
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 03-14-2010, 10:30 PM
  2. Removing Engine and Tranny Together for Dummies Like Me (Write Up)
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2009, 06:24 AM
  3. Key Programming
    By designsquire in forum General Tech Discussion
    Last Post: 07-28-2009, 08:42 PM
  4. PowrTuner for dummies?
    By PitchBlackSS in forum PCM Tuning
    Last Post: 02-22-2008, 01:43 AM
