Thread: Argghh!!! Log didn't save??!
Results 1 to 5 of 5
  1. #1 Argghh!!! Log didn't save??!
    Barksdale AFB, LA
    So, is there a secret to getting a long log to save on the PT? I first played with it this morning and it saved the quick "test" of me slapping the space bar a couple times, but not my 25 minute drive.
    Once I realized this, I fired it up and it scanned and recorded for over a minute just fine while I was sitting back home. Even saved it too. So maybe my log was too long? Any recommended settings?
    2009 Subaru Impreza WRX STI
  2. #2 Re: Argghh!!! Log didn't save??!
    PA
    Quote Originally Posted by Sabrewings View Post
    Yes, there are recommended settings. I cant recall them all offhand. But I know it is recommended to scan to external csv. This will create the log in the Log folder in the PT directory. And I have scanned for over an hour and it saved without a problem. But every now and then, I do run into a problem with my logs not having the right info, or missing sections. Just part of the game I suppose.
    Oh, but one thing I do know is that you need to shut down the PT program before you can access the log when saving to external csv.
    But the recommended settings are in a post on the PT website. I will see if I can find them.
    2001 GSE
  3. #3 Re: Argghh!!! Log didn't save??!
    PA
    Ah, here it is.
    Argghh!!!  Log didn't save??! Attached Files
    2001 GSE
  4. #4 Re: Argghh!!! Log didn't save??!
    Barksdale AFB, LA
    Much appreciated! I've got the opportunity to scan again later today, so I'll see how it does.
  5. #5 Re: Argghh!!! Log didn't save??!
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Even though that is how I have my pt setup that is a great piece of info there Zeff.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  1. Save Windows XP: Sign the petition!
    By BackInBlack in forum Off Topic Discussion
    Last Post: 05-28-2008, 10:07 PM
