Thread: wipers only work on high level. 2008 GP Gxp
Results 1 to 8 of 8
  1. #1 wipers only work on high level. 2008 GP Gxp
    Apr 2013
    Salt Lake City
    hi it's just another random question. I went to use my washer fluid today and realized my windshield wipers only work on the highest level. Also when I try to stop them they stop immediately instead of going back to their original position. also when I push the button for the fluid it sprays but it does not move. I checked my fuses and I can't seem to figure out what the problem may be. thank you very much I appreciate it
  2. #2 Re: wipers only work on high level. 2008 GP Gxp
    I live here. DirtDog's Avatar
    Jun 2012
    Maybe the motor for them isnt working right. Its not hard to replace but I dunno what they cost
  3. #3 Re: wipers only work on high level. 2008 GP Gxp
    could be the multi switch. being it controls the speed and washing.
    everything else work on the arm, blinkers, cruise, high beams, and hazard lights?
  4. #4 Re: wipers only work on high level. 2008 GP Gxp
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    The wipers have their own arm on 04+ cars
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  5. #5 Re: wipers only work on high level. 2008 GP Gxp
    Apr 2013
    Salt Lake City
    yes everything on their works perfect aside from the low levels of wipers. it's almost as if there isn't even a motor there it doesn't make a noise or anything
  6. #6 Re: wipers only work on high level. 2008 GP Gxp
    Jun 2012
    Get a volt meter and check for current at the motor when the switch is on one of the low levels where it doesn't work
  7. #7 Re: wipers only work on high level. 2008 GP Gxp
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Switch is what I usually see when this happens. You move the switch all the time especially if you're like me trying to dial in the perfect wiper speed lol.
  8. #8 Re: wipers only work on high level. 2008 GP Gxp
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Switch or motor. The motors have logic if the board is junk it'll do the same thing. I can pull a diagram for you and just test for grounds coming out of the switch on each setting.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. My 2008: Work in Progress!
    By FriboRage in forum Members Rides
    Last Post: 04-17-2012, 08:33 PM
  2. 2000 grand prix - wipers only work on high speed
    By claude grand prix in forum General Tech Discussion
    Last Post: 02-27-2012, 10:47 PM
  3. Wipers will not work......
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 04-21-2011, 10:44 AM
  4. P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    By WonBadGTP in forum General Tech Discussion
    Last Post: 02-14-2011, 08:41 AM
  5. Wipers don't work at all
    By kevinpope in forum General Tech Discussion
    Last Post: 09-12-2010, 01:10 PM
