Amping speakers?
I second this. It is the best plan if you want to run power to all 6 speakers. Just use the stock power coming from your new HU. Should be enough to pump those little speakers, although I would look into a set of bass-blockers so your not feeding the lows into those little guys using like 15w RMS from your HU, that would be bad news.
I'm not sure I could run them from my head unit, because I am bypassing the Bose amp and wiring...
Run power wire down the center of the car.. FIXED! See if it has noise. If it doesn't don't worry about it. RCA's seem to be more effected by running them near the power wire than speaker wire in my experience.
First of all, fix the ground and remove the ground loop isolator. That's honestly a bandaid for something that really should be there in the first place. Also, you can run speaker wires next to your power wires, since the signal is already amplified, any interference would be unnoticeable. That being said, don't ever run your rcas next to your power wire, it is an I amplified signal and anything it picks up will only get louder.
Relax brah, everything works fine. Once i reinstall my subs then ill fix it, in the mean time, its no big deal to me..
Yeah man for sure. Just wanted to make sure you got the best from your system. You should mount your amp in the trunk silly goose.
Umm, I've heard good things about people mounting them to the back of the rear seats or the pass through if your amp is small enough.
