The Devil (updated 01/22/13) ive returned!
Re: Omega Red (updated 9/9/11) hmm...
the oil feed and return lines for the turbo...zzp charges 129$ for nylon hose and brass fittings, i have all nice AN lines for way less. as well as a sweet IAT setup. if you go turbo ill be happy to share
Hmm....
Borg Warner*56mm*turbo (optional extended tip turbo available)
TiAL 38mm wastegate kit (external dump only)
TIG*welded 304 stainless steel*crossover
TIG welded 304 stainless steel 2.5" downpipe
Powder coated intake pipes*
Oil feed and return system
High temp silicone connectors
K&N air filter
Custom PCM programming*for your modifications
Crankcase breather
Autolite 103 plugs gapped for your setup
All required hoses and gaskets
LT1 MAF with wire adapter (04+ GP only)
Coupler and T bolt clamps for MAF (04+ GP only)
Modified charge tube (04+ GP only)
Vacuum hose adapter (04+ GP only)
Fuel rail spacers (04+ GP only)
All installations accessories
Fully detailed instructions
That's the content of the z3 kit, with injectors it's gonna run about $3k
forgot to share pics of my projector stuff.... i had a case of the couches lol
here ya go
box o' sh!t
morimoto mini h1's
going to 5000k instead of the 6000k i have now.. i want brighter!
yep thats right, going black on the shrouds, these are graphite's btw
should be able to order my aftermarket headlights tomorrow so i can finish this project :th_nanana:
Re: The Devil (updated 9/29/11) retros under way
here's some preview pics, i took enough pics to make a write up, but im lazy so ill do it some other time lol
and im tired so i dont have them sealed back up yet, but they are aimed, and glue and whatnot is drying overnight
:D
Looking good. How big of a hole did you cut in the reflector and our you mounting them w/ the washer method?
you have to open it up clear to the second ring in to get the housing to close, it was a B!TCH
Yea I sold my original retrofit and now i'm figuring out a different way of mounting them to get the cutoff perfectly straight. If you don't mind can you send me pics of the assembly.
I'm glad you went with a matte black shroud.
^this, and get em installed already! gdam you i want to retro but i'll prob just pickup a set of diode's HIDs
edit: i see you've named the evil twin
Yep lol, they are on the car. Ill probably havee to get another set of headlights the passenger side doesnt fit right. Ill post pics soon
Re: The Devil (updated 10/2/11) retros b!tches
snapped a couple pics, sorry i havent been on much lately guys, my computer took a sh!t on me and im only able to get on from my phone, came over to my moms to upload a couple pics for ya
my camera doesnt do the cut off line justice in this pic, ill have to retake soon
and heres some more
:D
