The Black Beauty "Updated with more pics & Build FINISHED"
Re: The Black Beauty "Updated with more pics & Build starting very soon"
Where did you get your projectors and which tips are you running? Both look amazing. Also, how did you do the pinstripe above the lower portion? I am very impressed.
well the headligths r the spyder auto ones i believe I got them form a member on here. The tips are 3A racing exhaust tips. (can find them on ebay)... And the pinstripe... i toke both bumpers off and hand painted it with a brush lol (very time consuming) :D but yup. thank you very much sir
once i detial my car completly i will get better pics of the tips. Bcuz i have kinda repostitioned them so they look better
ok i wanna get some opinions here.... who thinks i should try some gunmetal torque star rims on my car...??
leave your stock wheels alone and get aftermarket wheels...
u can get a deal on bullits and ud rather paint ur silly t-stars? i call phail.
ok well guys time has come for the build to begin :) im gunna make a list of all the parts i ahve and i want everyone to make sure it looks like i got everything and if im missing something please let me know :)
xp cam
105 springs
new timing chain + dampner
conversion gasket set
metal LIM gasket
180* tstat
SLP headers
exhaust gaskets
lower solid engine + tranny mount
poly dogbone round and square bushings
new BBV
3.2 pulley and hub
stock pcm to be custom tuned
42.5# greentop injectors
ngk tr5 plugs
zzp sp wires
your gonna also need
side cover gasket
cam bolt
rtv (black)
valve cover gaskets
rocker bolts
s/c gasket
t/b gasket
cam lube
plenty of oil (to change the oil and wash down the lifter valley)
coolant
coolant elbows
a new s/c belt for your new pulley
valve locks
valve seals
zzp modded retainers
that's all i can think of for now. Me personally would never run solid engine and trans mounts. You can get some nice oem replacements from rock auto for cheap
also make sure you get the crow 105's not the comp cam crap
good luck! if you like the feeling of the car pulling where it would normally slow down, you will like this cam
side cover gasket HAVE
cam bolt
rtv (black) HAVE
valve cover gaskets (just got replaced so reusing them)
rocker bolts
s/c gasket HAVE
t/b gasket HAVE
cam lube
plenty of oil (to change the oil and wash down the lifter valley) GET FOR FREE
coolant GET FOR FREE
coolant elbows HAVE
a new s/c belt for your new pulley HAVE
valve locks
valve seals HAVE
zzp modded retainers HAVE
and im sing ls6 springs erik
LOL Cam bolt.
Reuse it.
Also...since I hear no cam clips...
