Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
A T76 is NOT the turbo to do "low boost power" on, as you are really not even moving into the efficiency range at "low boost". Based on what I have observed on a stock head 3800, you would probably need to be at 30psi to see peak efficiency out of a t76. Every psi I add past 20 adds huge WHP each step up.
Doing 700whp under 22psi is most likely not going to be possible without some tricks, but you should be able to do mid 600s without much issue. Manuals are cake to make power on a dyno with.
LOL 700 whp on stock heads? And a rediculous over sized turbo and a manual? Please post this over on the other site so we all can lawlz without getting in trouble.....
Why all the hate on the 5speed allthe time? I hope you realize I have an 04 comp g that dynoed 581whp at 21psi through an auto aswell. The heads are now off this car and going onto my red 5-speed car.
Has nothing to do with hating. It has to do with the truth. Manual numbers are inflated plain and simple. Too bad most people on this forum doesnt understand that. But I guess if it is good enough for the supra crowd then its good enough for us. I do hope you succeed in your build, and hopefully that clutch holds because that would be a great benefit to the fiero world. But to boast about a 700 whp build with inflated numbers is plain asinine.
