kind153
--->> Listen..
I tried to reduce a noise,, but didn't help much. I will try to record it with better equipment later.
It's heard when I drive, cold or warm, with steering wheel right from center.
It varies with speed.
It doesn't sound when:
1. brake is pressed
2. steering is, even slightly, turned left. (or it's heard but quieter,, i don't know)
I'm pretty sure that it's coming from front left.
I have front brake rotor and pad replaced in June 2009, rear pads Feb 2010.
I've searched,, couldn't find much.
Someone wrote to check if nuts are torqued right(?) I don't know.
Need help! Not only it's annoying, I am worried.
3/22/2010
UPDATE: I notice the pitch changes (goes higher) as brake pedal is pressed. It finally goes away when brake seems to slow it down.
UPDATE2: after relatively heavy snow (southeast kansas here), it seems to be gone(??)
The noise might be gone, but my curiosity still remains.......... What is(was?) going on?!
1. brake is pressed
3/22/2010
