DOD is also horrible on the transmission
I'm pretty sure that the torque converter constantly engages/dis-engages with it.
Depending on the speeds you're going this can be constant (50 mph seems to be the worst spot for me).
Parkave91 or someone else with hptuners could probably comment with more concrete proof; however, more heat, more wear, more prone to failure with our already ****ty converters.
Overkill pcm would be a better option than diablo
I just sent my computers up to Overkill in Canada. I paid $180 for the "send in special". I had to pay $40 to ship my computers to him and the $180 for tuning and return shipping. My car runs and shifts WAY better now. I had DOD turned off completely. He also turned off or turned down the stabilitrak system so I can burnout going around a corner now without the damn computer limiting the power and making the car bog out. This Overkill tune just woke my car up. It seems a little more powerful now. The trans shifts WAY better too. You can also rev it past 4000 RPM in park too unlike the stock tune. It just makes the whole driving experience of my car better. It was worth the $220 FOR SURE.
http://www.getoverkilled.ca/LS4.html
The stabilitrak system cannot be edited, what he edited was your traction control, which I dont know why he would that considering we have a button to turn it off. Not to mention doing burnouts around a corner is horrible for your differential. The stabilitrak system is not programmed into the ECU it is programmed into the electronic brake control module, which we have no access to.
Because the button does not disable traction control measures completely. Diff score etc tps max, abuse mode and tq mgmt measures need to be edited.
torque management is a separate function from traction control, thats the reason why it doesnt turn off when you turn the traction control off. -_-
