My 2002 Camaro SS Polished & Coated
The Guz
Active member
Well this is my personal car. Before I go on to the photos I would like to give a little background story about this car.
I am technically the third owner. The first owner was a car collector who had this car in his personal collection. He passed away and the second owner picked it up at a car auction and then I purchased it.
When I purchased it, the odometer read 3,000 miles. I could not pass the deal and low mileage. I have had it for about 10 years and it's currently sitting at 14,XXX miles. This is the garage queen as they say.
I've made some changes throughout the years. It has the full hotchkis suspension (sway bars, lowering springs, trailing arms, front strut bar), koni single adjustable shocks, 35th anniversary wheels and an original rear center lip with a Magnaflow cat back exhaust that I modified to be center mount. I only have an intake, exhaust and a tune. I don't want to go all out crazy with the engine mods. This is as far as I am going with those.
It's been about a year and half since I last did any sort of paint correction/polishing. Since it sits in the garage a lot more the paint stays clean and LSP just lasts. A year and a half ago I used M21/M26 and there was still something on the paint with maybe a spray wax here and there.
Onto the detail specifics.
This is what I used:
Wash: Adams New Car Shampoo, Meguiar's Wash Mitt
Paint Decon: Ironx, Clay, D155 clay lube
Wheels: Adams New Car Shampoo, various brushes
Tires: Meguiar's D143, Blackfire Total Eclipse Tire Gel
Polish: M205 with a Meguiar's thin yellow polishing pad, D302 with a foam finishing pad
Coating: Ameriarmour by Americana Car Care
Tools: Meguiar's MT300 (died in the middle of polishing), PC7424XP
I started off by using Mike Philips wash method. It is not the first time I used it and it won't be the last. It just saves time. Here's the link to that. Helps if one has a foam gun.
http://www.autogeekonline.net/forum/...shing-car.html
Here's ironx at work on the rear bumper
The one issue that this car has is the typical sail panel adhesive issue. The adhesive seeps through from under the panel. GM no longer replaces the panel under the TSB. Repainting it will not fix it. The only real fix is replacing the panel with one from a 93-97 model. In the heat the adhesive starts to melt and stains the surrounding area. It becomes an eye sore.
The paint looked pretty good with very minor defects or love marks. It was a bit hard to capture them but they were easily polished out.
This is the combo I used. M205 on a Meguiar's yellow thin polishing pad and D302 on a black thin finishing pad. I have always been curious about using D302 on a foam finishing pad as it was talked about so long ago on the Meguiar's forum. I wanted to see if I could amp up the gloss and refine the finish even more.
I was using my Meguiar's MT300 at the beginning and as I was using it for a better part on the front end, it started bogging down and eventually stopped working with the trigger in the on position while on the drivers side fender. Turns out the cord is causing the machine to not operate properly (I have a thread on this if you search under my name). I was bummed as I had only used it on 3 cars and 1 truck prior to this one. It's a good machine when it's working properly. I had to resort to plan B and use my PC7424XP. It's a good thing I had it as a back up.
I do have to say the new thin pads work very well with the PC. It utilizes it's power more efficiently. I was impressed with the results I was getting. It took a little longer but the PC was a workhorse and got the job done.
I followed up polishing with Car Pro Eraser and 2 coats of Ameriarmour.
Sun shot of the corrected paint.
Here are a few reflection shots in the garage after it was coated.
The passenger side of the sail panel with more bubbling. No more adhesive residue.
Pulled the car outside and took some various photos. There is no flake in this paint.
Various gloss shots. Not bad considering it's white.
Tires dressed with Blackfire Total Eclipse
With the engine bay so clean I just used Blackfire All In One Trim & Tire Protectant
Great job as always Mike.
So did the D302 work as planned? What kind of refinement did it offer over Ultimate polish?
And what kind of shelving unit is that?
Thanks. It worked out pretty well. It has less cut than ultimate polish. I haven't used Ultimate polish in so long after switching to M205. Hard for me to even compare the refinement from it. M205 actually finished out very well on it's own. The sail panel paint is softer that the rest of the paint so D302 worked very well on that area.
It's a craftsman shelving unit. That's just one side of it. There is another in front of the car.
You should drive it more, awesome car but kinda sad that it just sits so much.
Not that sad when I get to look at it and drive every now and then. When I do drive it the commute is rather short so the mileage just stays low.
But you live in cali, where it like never rains anymore and thats exactly why I'd drive it all the time.
I couldnt enjoy a vehicle by just looking at it and doing a 5 mile drive to dairy queen once every other week.
The finish on your car looks amazing, shows its been well cared for. Too bad it has the roof issue, those are a pain. Solid colors do have a nice gloss don't they?
Thanks. I do agree with you on solid colors being glossy.
But I drive it everyday. Though my work commute is 5 miles daily, I still drive it all over town or where ever. Miles stay low because of my job.
My commute to work is less than yours. So even if I drove it everyday the mileage would be low.
you're "that guy".
when the weather was right and i was going anywhere with anyone i'd have the car out of the garage. why are you saving it for the next guy? or when you die and own a billion year old, low mileage car? lame. weak sauce.
(qualifications: i've had a couple drinks)
