New MazdaSpeed3
Re: Gins 04 Comp G
Well it ran 14.2 but it's boost limited in 1st and trapped over 100. Would be interesting!
I honestly could of done better if the trans wasnt ****ting out the entire day. It was a scary ride home. Called the jy i got it from cus i purchased the warrantee with labor so hopefully they can find or ill be rebuilding it.
Re: Gins 04 Comp G
.5 seconds and 6mph slower than jayrocas on e85 xp cam and ported heads!
damn good runs imo for the mods you have!
Re: Gins 04 Comp G
Got a couple more pieces to the puzzle.
And thanks to Bill
And because im Anal she got completely ripped apart and cleaned inside and out.
Re: Gins 04 Comp G
Oh and because i was bored
Might rebuild it idk, wasnt a broken band like i initially thought. Yet to look at the clutch packs.
Re: Gins 04 Comp G
Happy to see it go to a good home. I felt bad for not having time to clean it. Looking great...enjoy!
Re: Gins 04 Comp G
So its been awhile since I've updated this thread. Lets just say i have some big things happening soon.:th_thumbsup-wink:
Re: Gins 04 Comp G
Re: Gins 04 Comp G
Almost ready :D Clutch looks great, went with the stage 5 cus racecar. Also got my hydraulic lines and fittings all hooked up to the master and slave. Also got a Wilwood universal clutch pedal which seems like its going to work perfect. Got my tune all squared away as much as i can without the swap being complete. There is a factory camaro flywheel sitting in a junkyard a town away so ill go grab that this week. Found some factory axles and a subframe also in the junkyard that needs to be pulled for cheap. All i need now is the flywheel machined, oil filter adapter plugged,redrilled and threaded. Oh also need to order a tub of poly to form the trans mount and mockup/weld the engine to trans bracket. purchased 5 quartz or gm syncromesh so i can fill/drain/refill the trans for peace of mind.
Re: Gins 04 Comp G 5 speed?
When's the estimated time of being finished?
I'm anxious to see how this works out.
Asap. It all depends on if/when im moving and what the weather looks like. Im currently looking for a house with a garage. Hope to be moved in the next couple months and the weather should be good with the next couple months aswell. I def plan on having it done by spring/summer.
Right on!
Local here did a full G6 center console and everything out of a 6-spd car into his '98 turbo car...good luck with it, looks good so far
