DIY rusted strut tower fix for dummies(Ive never done this before)
Howdy Bill. I think I skipped this one. I believe this is what ITHURTZ was talking about when a cobalt bit was mentioned. This is not a cobalt but a high speed which is what I generally prefer, of those two. But its the flat-nosed variety, with a little pilot point that likes to snap off. Cobalt ones are black and harder but won't take the heat too well. Either would work for this. So there are several ways to remove welds, but the Blairs are my favorite. They work as fast as if the part was bolted on.
Matt, I also forgot to mention that in this case its probably fine to drill your pilot hole all the way through. Makes centering so much easier.
...AND ... that if all else fails, you can use a regular drill bit or better yet a stepped bit. You would drill away both layers of the whole weld spots then make new plug weld holes right next to the old ones. Just a thought, I'm sure you're ready to get past this so the car can be mobile again.
Ah. OK yeah thats not a spot weld removal bit but is what I referred at as a "regular bit". Meaning the shape of the point. In cobalt (looks nitrided too). Still works! I have a $9 set of nitrided step bits from HF that I've used for many years, those would work fine too. Heck I've used a plasma cutter to do it before, lol. Working in this spot, neatness isn't as important. Just need holes! Maybe our hero will get it whooped over the weekend...
this is deffiently taking longer then intended but atleast I'm learning alot with your guys help which I can't give enough thanks for.
Anyways that spot weld cutter was difficult broke the pin in it after 2 holes. So went with a regular 3/8s bit I think HS one and got about this far.(after 4 hours half of that with a cordless drill)
Still 3 holes I can see that I havent drilled but it still seems really stuck. Should all the spot welds be in the same spot as IHURTZ? cause I cant see anymore on mine perhaps its just 3 remaining holding it though?
Borrowed this corded drill from my buddy and got a colbalt bit hopfully this goes a little better now
Weld locations should be very similar if not exactly the same, if you guys have the same kind of car.
It will be stuck good until all welds are out.
Be aware though, that some welds may be slightly larger than the cutter or bit. So they would still be holding. Same thing if you didn't exactly center the weld, the edge of it could still be holding. Thats when a step bit would be handy. If y9u have them all drilled out and can tell that one or more are still stuck when you try to pry it off, try to see which ones are still stuck and dish out that hole with the grinder. Just a little, then pull on the brace more and see where the weld is stuck.
Robots weld it at the factory and as long as it passed inspection, a sloppy weld or two wasn't a big deal to GM. So you do find oddly shaped spotwelds, and they don't always quite fit into a 3/8 circle. Especially if the pilot wasn't centered. Thats one of the hard parts. Find you a good 90 degree angle pry bar of some sort and get under that brace so you can pry against the tower, because its not unusual to have to swear a bit getting a part like that off. Pry, grind, drill, cuss, repeat. Don't have your face under it when it pops off!
That flat-nosed bit I showed... they have 6, 8, and 10mm versions. On structural pieces like this, welds tend to be larger than the 6-8 mm and many times I'd reach for the 10mm.
Remember, its like breaking a single strand of wire by bending it, kinda. If you get the brace loose enough to move, rock it back and forth to loosen until you can eventually rip it off there. Don't worry much about bending the brace, you can hammer that flat on the ground after its off. They sure put a lot of randomly placed welds in it, didn't they? Thats overkill on purpose because sometimes the robot misses.
After the brace is off- theres an option to consider, let me explain:
You could weld up all the holes in the brace while its out, then grind them flat on top of it. Then you would have little or no drilling left to do because you would use the old weld holes in the tower. Plug weld it from inside the trunk and gravity would be on your side with the weld kernel. Since the heavy gauge piece is on the bottom, theres every reason to do it that way, but you would be in a very tight spot and up there by stuff that could burn or catch a spark. But man, it would weld up better that way.
The alternative is to drill new plug weld holes near the existing welds in the brace and leave all the holes you just drilled in everything. That means you end up with swiss cheese holes all around your strut mount that go all the way through to the trunk. Gotta seal those up, and hmm, did it get weaker? Maybe. Plus, you would be welding the thick lower brace to the thin upper tower metal while defying gravity with the weld kernel. Less than ideal.
I would probably end up doing as many from the top as I could. A guy could take out the speaker shelf and maybe gain some access from inside. Be sure to protect the back glass if you weld any up top. Wetted cardboard ain't bad for that.
Sorry such a long post, but I'm glad to share my experience. These bodies just don't rust much here, so I've never done one. Fixed plenty of bent W-bodies though.
Matt I had that same problem, drilled all my spot welds, and found out I had 3 not perfectly round spot welds that were still attached to the car. I just used a screwdriver to try and "pry" the plate away from the car and see where the metal seperated and where it was still stuck. I wont lie though, I got fed up with one of them and went nuts with the air chisel, 50/50 regret that haha. Good to see your getting under the plate (only took my 30min to get it off btw :))
half hour is pretty fast I can't believe the difference the colbalt bit made probably would have saved me 3 hours yesterday. The colbalt goes in like butter took me less then 10 mins to finish those last 3 holes the other side should be much easier. Took abit of prying with the crow bar and the claw of my hammer but actually came of without too much trouble gotta love the sound of those piece of metal breaking apart.
started to clean it up a little bit should I bother cleaning out all the rust on the tower? for rust proofing. Also It's gonna be interesting trying to cut the compression bolt hole into the patch metal with my angle grinder.
Cleaned up the inside abit for now I think I will try and do a few welds in here not sure if I'll be able to get the one's closer to the back of the trunk from inside of the trunk. But maybe Ill do half inside the trunk and the other's underneath the strut tower mount to minimize overhead welding. Also gonna have to try and find some cheap way to block the rubber/foam liner in between the seat and the back of the trunk. the foams pretty close to were I'll be welding I could see it going up with a few sparks. But other then that hopefully I get'er dun tomorrow after work.
This is great, I turn to the claw hammer at the house for everything. Again, I'm glad to see this repair demonstrated. It looks to me like you're doing fine. Them pics are kinda small though, lol. I learned my lesson about showing fresh welds on the interweb. People don't get it.
Spray bottle some water onto cardboard to block off the sparks. By all means yes, get that rust off the tower and coat all the bare metal that will be hidden behind the brace. If you really want to knock the rust off without hurting the metal too bad, you need some sandpaper or something like a scotch brite wheel from the drill bit store maybe? Don't want to thin that tower metal any more than necessary.
Cutting the hole-
Cut a triangle instead? You da boss. Or you could drill a series of holes with your small bit real close together. Perforate a circle, then knock that out.
Sometimes it be's that way. Man, I'm glad you turned him onto that bit. We had to drill some stainless oh, 16 gauge awhile back and everybody in the shop just about ate up all their bits trying to get holes in that stuff. If you guys want some super-handy bits though, try some stepped or "uni" bits. I use them often and its better than having a boxful of sizes if you're working sheetmetal.
Oh and Matt- sorry the cutter didn't work out for you. But I got about the same use from that product as you did. With lots of practice, I can now usually wear out a cutter before breaking a tooth off. Its something that a guy has to get a feel for. Better luck on the next $30, man.
Uni's are nice, Used mine once and lost the dam thing, there went a big chunk of change.
Matt, I set about 5 fires when doing my rockers and struts. One of the times I was 99% sure my car was going up in flames. I never ripped my interior apart so fast before in my life to put those flames out. That big one was in the rocker area though, but from the bottom of the car to the bottom of the coupe small window. After that I armed myself with a big spray bottle of water.
You also didnt need to drill 100% through the metal, only the main plate was needed! I just replaced the factory spot welds with my 3/8 hole and filled it with the mig.
Oh ya, when I delt with my rust I used a siphon blaster, then figured I would try out rust bullet, and their blackshell top coat.
Rust bullet applied to my rockers, 2 coats
8byu by smetters20, on Flickr
Then topcoated with 2 coats of blackshell, dries hard as a rock.... on anything it touches
6bf461c5eb0decb73ad177ab77d8cd7e by smetters20, on Flickr
I also old schooled my undercarriage
db7102d2addb3d9fa5203030a428f6e0 by smetters20, on Flickr
97ni by smetters20, on Flickr
Its fun to try new and old things out
So its like raining every other day over here was dry as could be before I dropped the car seems like **** luck. At least I live really close to were I work but damn over a week now on this fix I hope I get it done tommorw. Pulled a stupid move today and ran out of cut off blades after 4 so I live in a small town and it being sunday I'm out of luck for anything being open. Couldn't finish my patch...so close though but here's the progress
Marked the comperssion bolt from what was left of the metal up top think im gonna cut it bigger then need just incase. Had to trim it a few times after the orginal cut bit fits pretty snug in there now also took the hammer and tryed to bent on a slight angle so it wasnt so flat made it fit in much better cant really tell so much in the picture its not a huge bend.
Got the 1x1 up the holding in place to get an idea of what it looks like in there. Also think im gonna use that to hold it there when I tack it but I have to finish cutting and drilling the strut mount holes first. Also on the far right side I think I'm gonna weld in a smallish patch on 45 degree angle till it connects to the cleaned up metal on whell well to my patch and there no hole there and it looks clean hopefully.
So back to work today..Still not done wish I was but taking my time making sure I'm not messing anything up starting welding the new sheet metal in.
Welds look pretty rough really hard to get in up top there have to weld with one. But I think there mostly penetrating and I plan On welding from the wheel side aswell.
Coming along alright tacked it from wheel side to start off used the 1x1 to hold up the sheet metal well I put couple tacks in. Only problem I'm having now is a couple of my edges are slightly raised to the sheet metal behind it. I tried bashing in with hammer didn't seem to do much. Anybody else have any suggestions or had similar problems?
Welding in my first spot weld hole conveniently in one of the spots I drilled to spot weld from the top of the sheet metal(not :| ) So ended up filling the hole. I'm gonna spot weld couple from the top then get 4 or so on the bottom and spot weld the edges. Really Really hoping I'm getting back on 4 wheels tommorw!
Looks to me like its coming right along. Having an assistant back up (maybe hold a piece of 2x4 or a metal dolly against the backside) of what you're hammer bashing. The hammer has more effect if the work piece can't bounce when you strike it.
bang bang done and done didnt take as many pictures I would have liked to near the end really started getting in a rush trying get this thing back on the road here's wt I got though.
almost forgot to take pic before I started putting primer on . Had to drill 1/2 holes for the tower bolts to come through into the trunk. Also patched up at big hole on right side. Burnt through a few times solid spots welds on it though. Plus its connected to rusted metal is more for winter proofing and looks then structural.
For sure man meant to make that last post a longer I have more pics somthing just came up I'll add rest tonight or tommorw thoughfor sure. And I just put a tar spay or ashplaht somting over the primer
These pics are gonna help me out alot, as well as yours ITHURTZ. Due to the lower molding I had no idea my rockers were getting that bad, as well as the bottom portion of the quarter panel in front of the rear wheels. I was under the car replacing both of the rear brake lines and spotted the cancer. I poked around on the rockers and the hole just kept growing on each side.
I just checked the rear strut towers, and even though they look really good from the wheel well, when I pulled the carpet back the passenger side has a nasty spot right on the top. I have been kinda bummed about this evening as my GTP was the first car I ever bought that I really wanted. I realize the car is getting old and all, but I would rather fix it than get another car. Its almost like I let the ol' girl down by not noticing what was going on(the car has always been a girl since the day I bought it;).
One thing I would like to buy new is the steel piece that goes behind the lower molding. Mine is pretty bad, but not so far gone that it will be impossible to fix. I would rather just buy a new set as to waste time on that part when I could be spending that time on another area of the car.
