It's all good bro!I took too long to type...
That's a good point! Now, I have to think about on what I want to do.oh, if you plan on doing a some crazy build down the road its best left in the rear header, if all your doing is a 3.4 pulley its fine in the crossover.
When I do this and block the back tires, can I jack the car back up in neutral? So, I can move the engine back and forth as I work on it.put the wheels back on the ground. make sure the cars not hanging on the park awl in the trans, block the back tires and put it in neutral engine should be easier to pull back, or be close to where it belongs.
i see no issue with jacking it up in neutral. I do it all the time haha. block the tires and use the parking brake. you should always use the parking brake and or block the rear tires when jacking up both front tires. im pretty sure putting the trans in park only locks up the two front wheels, sooo if they are off the ground anyways then why should it matter if they are in park or not? heheWhen I do this and block the back tires, can I jack the car back up in neutral? So, I can move the engine back and forth as I work on it.
