keonmakesbeatz
What is "your budget"? Is this your only vehicle?
This is my first and only car. My budget is really low but I'll save up for whatever.
Maybe your first item is to get it running with the fuel pump.
filter is cheap and some what easy to change. its 12 bucks well spent.
and have a drain pan to catch all the gas that will leak out when the filter is removed. dont have your head under it while removing it lol gas in the eyes sucks bad. gas also like to run down to your elbows, be ready for that, short sleeves.......
Well if his pump is already dead, why not just change it first.
It won't have any pressure to begin with.
Needing bearings is a standard option for W bodies (it's that common)
Catalytic might be causing the P0300 (multiple misfire) and the bogging feeling etc.
your coolant is dex coolant, its brown and crappy. flush it clean, then re fill using the green coolant.
One more question; I really want a manual car. What manual transmission would work with the 3800 without having to fabricate parts and what not?
None. It's a completely custom job pretty much
How do I properly flush the coolant?
Btw I have a Chilton manual for the car. Would this answer a lot of my questions? Sorry that I have so many questions. It's my first car and I want to do work on it but I haven't done much with cars and I don't wanna mess things up by doing things the improper way.
remove the t stat
top as needed till its ready to be bled of air.
